Introduzione
This guide will take you through the steps required to change your screen and get a clear view of your picture.
Clean the broken or cracked screen as best as possible.
  • Clean the broken or cracked screen as best as possible.
  • Place the suction cup on the damaged screen.
Aggiungi Commento
While holding the suction cup flat against the camera screen, suction the two together by pinching the orange handles to meet at the center. While holding the suction cup flat against the camera screen, suction the two together by pinching the orange handles to meet at the center.
  • While holding the suction cup flat against the camera screen, suction the two together by pinching the orange handles to meet at the center.
Aggiungi Commento
Grab the handle of the suction cup and gently lift it up at an angle, as demonstrated in the picture. Remove the plastic screen from the camera. Release the broken screen by pulling down the lever of the suction cup.
  • Grab the handle of the suction cup and gently lift it up at an angle, as demonstrated in the picture.
  • Remove the plastic screen from the camera.
  • Release the broken screen by pulling down the lever of the suction cup.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Michael Peck
Membro da: 14/04/2014
134 Reputazione
1 Guida realizzata
Cal Poly, Team 3-41, Maness Spring 2014 Membro di Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
4 Membri
5 Guide realizzate
Be sure to measure the size of your screen before buying the suction cups. I got the heavy-duty ones and then found that they were too big for my Rebel T1i screen.
cmorris - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 57
Tutti i Tempi: 3,359
