Introduzione
This guide will provide you with intructions to take out the existing broken eyepiece and replace with a new one.
Strumenti
Parti
If necessary, remove the rubber grip around the eyepiece by gently peeling it off. Use your index finger and thumb to grip the eyepiece by the sides.
  • If necessary, remove the rubber grip around the eyepiece by gently peeling it off.
  • Use your index finger and thumb to grip the eyepiece by the sides.
I am trying to find instructions on replacing the eyepiece glass as it has thin layer of super glue on it.
Natamus Maximus - Replica
Pinch your fingers together and wiggle the eye piece gently upwards until it is detached from the camera.
  • Pinch your fingers together and wiggle the eye piece gently upwards until it is detached from the camera.
Aggiungi Commento
Conclusione
Jonathan Lin
Membro da: 14/04/2014
512 Reputazione
4 Guide realizzate
Cal Poly, Team 3-41, Maness Spring 2014 Membro di Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,516
