Introduzione
This guide will teach you how to remove the viewfinder from your camera.
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Aggiungi Commento
Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
  • Using your finger, peel back the textured grip so the components are separated.
Aggiungi Commento
Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
  • Using the flat end of a spudger, loosen the connection between the front panel and the device.
  • Remove the front panel using your hands.
Aggiungi Commento
Turn Camera over.
  • Turn Camera over.
  • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Aggiungi Commento
Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
Aggiungi Commento
Lay the camera on its back.
  • Lay the camera on its back.
  • Unsolder the flash connection from the motherboard as noted by the blue circle.
Aggiungi Commento
Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera. Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera. Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
Aggiungi Commento
Unscrew the screws on either side of the viewfinder until the viewfinder can be lifted off
  • Unscrew the screws on either side of the viewfinder until the viewfinder can be lifted off
    • Two 8.5 mm Phillips screws
Aggiungi Commento
Conclusione
Kyle Reis
Membro da: 02/04/2012
49 Reputazione
4 Guide realizzate
Cal Poly, Team 14-9, Forte Spring 2012 Membro di Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,753
