Introduzione
This guide shows you how to install the front panel of your camera.
Parti
Nessuna parte richiesta.
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Aggiungi Commento
Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
  • Using your finger, peel back the textured grip so the components are separated.
Aggiungi Commento
Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
  • Using the flat end of a spudger, loosen the connection between the front panel and the device.
  • Remove the front panel using your hands.
Aggiungi Commento
Conclusione
Kyle Reis
Membro da: 02/04/2012
49 Reputazione
4 Guide realizzate
Cal Poly, Team 14-9, Forte Spring 2012 Membro di Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 667
