Introduzione
Removing the top cover of camera gives access to the LCD screen, control dial, and flash.
Parti
Nessuna parte richiesta.
Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
  • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
Aggiungi Commento
Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
  • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
Aggiungi Commento
Remove the battery from inside the battery housing and set the cover aside.
  • Remove the battery from inside the battery housing and set the cover aside.
Aggiungi Commento
Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
  • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
Aggiungi Commento
Remove the 6.4mm screw from the inside of the flash bezel.
  • Remove the 6.4mm screw from the inside of the flash bezel.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
  • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
Aggiungi Commento
Remove the 5.6mm screws behind the battery cover.
  • Remove the 5.6mm screws behind the battery cover.
Aggiungi Commento
Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
  • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
Aggiungi Commento
Remove the 6.4mm screw on the top of the inside edge of the battery hole.
  • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
Aggiungi Commento
Starting at the flash, carefully pull the front cover away from the camera. Starting at the flash, carefully pull the front cover away from the camera.
  • Starting at the flash, carefully pull the front cover away from the camera.
Aggiungi Commento
Remove the 4.3mm screw below the camera strap ring.
  • Remove the 4.3mm screw below the camera strap ring.
Aggiungi Commento
Remove two 4.8mm screws located on both sides of the eyepiece.
  • Remove two 4.8mm screws located on both sides of the eyepiece.
Aggiungi Commento
Pull the top cover up slowly.
  • Pull the top cover up slowly.
  • A ribbon cable is attached to the bottom of the top cover and the camera. Pull up very carefully to avoid damaging this.
Aggiungi Commento
Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
  • Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
  • If you pull the white tabs all the way out, just insert them back in to avoid losing them.
Aggiungi Commento
Conclusione
Mark
Membro da: 20/04/2011
88 Reputazione
5 Guide realizzate
Cal Poly, Team 8-9, Regan Spring 2011 Membro di Cal Poly, Team 8-9, Regan Spring 2011
CPSU-REGAN-S11S8G9
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,959
