Introduzione
Use this guide to replace a nonfunctional MIC Port or Remote Socket on your EOS 6D.
Cosa ti serve
Remove the viewfinder cover by pinching the sides and sliding it upward.
Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
Rotate the covers to the side so that you can see the connection ports inside.
Remove the following screws:
Two silver 5mm Phillips #00
One black 6mm Phillips #00
Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
Rotate the camera so the bottom is facing you.
Use the spudger to remove the light brown ribbon wire from the bottom edge of the camera.
Altre 2 persone hanno completato questa guida.
