Salta al contenuto principale
Canon EOS 60D Rubber grips Replacement
Cosa ti serve
  1. Canon EOS 60D Rubber grips Replacement, Rubber grips: passo 1, immagine 1 di 1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
Conclusione
Double stick tape, or rubber cement (placed carefully) should work well. Studio-mount (sheets of double-stick tape) cut to size should also work.
Altre 10 persone hanno completato questa guida.
Eric D
Membro da: 11/13/12
1.284 Reputazione
5 Guide realizzate
Un commento
Where can we get replacement grips?
Luke Lin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 44
Tutti i Tempi: 11,935
