Introduzione
This guide removes the side panel of the camera, allowing for repairs on the side lever.
Parti
Nessuna parte richiesta.
Open up the battery door. Open up the battery door. Open up the battery door.
  • Open up the battery door.
Aggiungi Commento
Remove the batteries from the camera by sliding them out into your palm. Remove the batteries from the camera by sliding them out into your palm.
  • Remove the batteries from the camera by sliding them out into your palm.
Aggiungi Commento
Release the side latch to open the back panel. Release the side latch to open the back panel.
  • Release the side latch to open the back panel.
Aggiungi Commento
Remove the two black 4.5mm screws above and below the latch. Remove the two black 4.5mm screws above and below the latch.
  • Remove the two black 4.5mm screws above and below the latch.
Aggiungi Commento
Using your finger, carefully pry open the side panel from the top of camera. Pull panel downwards to remove.
  • Using your finger, carefully pry open the side panel from the top of camera.
  • Pull panel downwards to remove.
  • Make sure to keep track of the small black piece of rubber under the latch.
Aggiungi Commento
Conclusione
Jordan Tang
Membro da: 24/01/2014
531 Reputazione
5 Guide realizzate
Cal Poly, Team 6-20, Maness Winter 2014 Membro di Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 204
