Salta al contenuto principale
Canon EOS 300 Front Panel Replacement
Cosa ti serve
  1. Canon EOS 300 Front Panel Replacement, Batteries: passo 1, immagine 1 di 3 Canon EOS 300 Front Panel Replacement, Batteries: passo 1, immagine 2 di 3 Canon EOS 300 Front Panel Replacement, Batteries: passo 1, immagine 3 di 3
    • Open up the battery door.
  2. Canon EOS 300 Front Panel Replacement: passo 2, immagine 1 di 2 Canon EOS 300 Front Panel Replacement: passo 2, immagine 2 di 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Front Panel Replacement, Side Panel with Lever: passo 3, immagine 1 di 2 Canon EOS 300 Front Panel Replacement, Side Panel with Lever: passo 3, immagine 2 di 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Front Panel Replacement: passo 4, immagine 1 di 2 Canon EOS 300 Front Panel Replacement: passo 4, immagine 2 di 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Front Panel Replacement: passo 5, immagine 1 di 2 Canon EOS 300 Front Panel Replacement: passo 5, immagine 2 di 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Front Panel Replacement, Front Panel: passo 6, immagine 1 di 2 Canon EOS 300 Front Panel Replacement, Front Panel: passo 6, immagine 2 di 2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Front Panel Replacement: passo 7, immagine 1 di 2 Canon EOS 300 Front Panel Replacement: passo 7, immagine 2 di 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Front Panel Replacement: passo 8, immagine 1 di 2 Canon EOS 300 Front Panel Replacement: passo 8, immagine 2 di 2
    • Remove the front panel by pulling away from the side with the lever.
Conclusione
Jordan Tang
Membro da: 01/24/14
590 Reputazione
5 Guide realizzate
Cal Poly, Team 6-20, Maness Winter 2014 Membro di Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Membri
32 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 857
