Introduzione
The top panel can be safely separated from the camera body, but it will remain attached by several wires and a ribbon cable. Separating the top panel allows access to several important components.
Parti
Nessuna parte richiesta.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
  • Remove the two 4.8 mm black screws above the lens on the front of the camera.
Aggiungi Commento
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Aggiungi Commento
Remove the 4.8 mm black screw on the left side of the camera.
  • Remove the 4.8 mm black screw on the left side of the camera.
Aggiungi Commento
Remove the front panel by lifting it away from the camera's body.
  • Remove the front panel by lifting it away from the camera's body.
Aggiungi Commento
Slide the outer eyepiece upward to remove it.
  • Slide the outer eyepiece upward to remove it.
Aggiungi Commento
Remove the two 4.75 mm black screws located  on the top of the camera.
  • Remove the two 4.75 mm black screws located on the top of the camera.
Aggiungi Commento
Remove the four 4.3 mm  black screws near the bottom corners of the eyepiece at the back of the camera.
  • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Aggiungi Commento
Slowly separate the top panel from the camera by pushing it upward. Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  • Slowly separate the top panel from the camera by pushing it upward.
  • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
Aggiungi Commento
Conclusione
Cal Poly, Team 8-8, Regan Spring 2011 Membro di Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,961
