Salta al contenuto principale
Canon AE-1 Light Filter Foam Replacement
Cosa ti serve
  1. Canon AE-1 Light Filter Foam Replacement, Light Filter Foam: passo 1, immagine 1 di 1
    • Open the film compartment by pulling on the release pin.
    • Use a 3mm slot screw driver to scrape old light filter foam cleanly off.
    • Then use Isopropyl Alcohol to assist in removing the old light filter foam.
  2. Canon AE-1 Light Filter Foam Replacement: passo 2, immagine 1 di 1
    • Placing light filter foam improperly could result in light exposure on film.
    • Cut the new light filter foam to size so it can fit in the slot.
    • Place the sticky side of the new strip of light filter foam over old foams location.
Conclusione
To reassemble your device, follow these instructions.
Altre 2 persone hanno completato questa guida.
Brad
Membro da: 10/04/11
47 Reputazione
1 Guida realizzata
UW Stout, Team 5-1, Zhou Fall 2011 Membro di UW Stout, Team 5-1, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G1
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 79
Tutti i Tempi: 13,094
