Introduzione
To replace the pressure gauges, you must first remove the shroud of the compressor. Even though the pressure gauges seem easy to remove, there is still some disassembly required to complete the replacement.
Parti
Nessuna parte richiesta.
Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench. Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench. Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
Aggiungi Commento
Remove the plastic shroud from the compressor. Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  • Remove the plastic shroud from the compressor.
  • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
Aggiungi Commento
Gently pull the wire attached from the pressure switch to the on/off switch.
  • Gently pull the wire attached from the pressure switch to the on/off switch.
  • It should come off the pressure switch with ease.
  • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
Aggiungi Commento
Gently pull the wire connected from the on/off switch to the motor of the compressor.
  • Gently pull the wire connected from the on/off switch to the motor of the compressor.
  • It should be the only wire keeping the shroud from being lifted from the compressor.
Aggiungi Commento
Using a Smart Wrench, remove the old/broken pressure gauge or gauges. Using a Smart Wrench, remove the old/broken pressure gauge or gauges.
  • Using a Smart Wrench, remove the old/broken pressure gauge or gauges.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Eric
Membro da: 09/10/2014
387 Reputazione
3 Guide realizzate
Cal Poly, Team 14-29, Maness Fall 2014 Membro di Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 628
