Introduzione
I will teach you step by step how to dissemble the device and replace the damaged buttons.
Strumenti
Parti
Nessuna parte richiesta.
Unscrew the screws on the top side of the device.
  • Unscrew the screws on the top side of the device.
Aggiungi Commento
Take the top lid off of the device.
  • Take the top lid off of the device.
Aggiungi Commento
Unscrew the screws holding the pink button sheet.
  • Unscrew the screws holding the pink button sheet.
Aggiungi Commento
Remove the button sheet off of the device.
  • Remove the button sheet off of the device.
Aggiungi Commento
Examine the button sheet to check for any damages that may prevent the buttons from working.
  • Examine the button sheet to check for any damages that may prevent the buttons from working.
Aggiungi Commento
Examine closer at the button sheet for sticks on the opposite side of the buttons.
  • Examine closer at the button sheet for sticks on the opposite side of the buttons.
Aggiungi Commento
If the button sheet or button is damaged, you may need to purchase a new button sheet to replace the damaged one.
  • If the button sheet or button is damaged, you may need to purchase a new button sheet to replace the damaged one.
Aggiungi Commento
Conclusione
To reassemble, follow these steps in reverse order.
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 159
