Introduzione
This guide will walk you through the process of replacing a dull or broken cutter blade on a Brother PT-D200.
Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you. Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
  • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
Aggiungi Commento
Locate the cutter blade unit (mint green) as shown in the picture.
  • Locate the cutter blade unit (mint green) as shown in the picture.
Aggiungi Commento
Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed. The blade is sharp.
  • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
  • The blade is sharp.
Aggiungi Commento
Conclusione
Blaire McCreary
Membro da: 24/01/2014
201 Reputazione
2 Guide realizzate
Cal Poly, Team 13-16, Regan Winter 2014 Membro di Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 978
