Parti
Nessuna parte richiesta.
Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
Aggiungi Commento
Remove batteries, cassette tape, and cutter blade.
  • Remove batteries, cassette tape, and cutter blade.
Aggiungi Commento
Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
  • Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
Aggiungi Commento
Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
  • Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
Aggiungi Commento
Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
  • Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
Aggiungi Commento
Using your index finger and thumb, pull out the golden ribbon from the green circuit board. Using your index finger and thumb, pull out the golden ribbon from the green circuit board. Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
  • Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
Aggiungi Commento
Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
  • Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
Aggiungi Commento
Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
  • Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
  • The ribbon is very fragile so be careful to break it when pulling up on the circuit board.
Aggiungi Commento
Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device. Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device. Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
  • Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
Aggiungi Commento
Conclusione
Haley Sweet
Membro da: 30/10/2014
425 Reputazione
4 Guide realizzate
Baylor, Team 4-4, Williams Fall 2014 Membro di Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 792
