Salta al contenuto principale
Brother PT-1010 Cutter Blade Replacement
Cosa ti serve
  1. Brother PT-1010 Cutter Blade Replacement, Remove Back Cover: passo 1, immagine 1 di 1
    • Open the back cover of the device by pressing on the indication arrow and pulling it open.
  2. Brother PT-1010 Cutter Blade Replacement, Locate Cutter Blade Unit: passo 2, immagine 1 di 1
    • Locate the yellow cutter blade unit as shown in the photo.
  3. Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: passo 3, immagine 1 di 3 Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: passo 3, immagine 2 di 3 Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: passo 3, immagine 3 di 3
    • Using your thumb and forefinger, pull up, applying a small amount of pressure until the blade loosens and comes out.
    • Be very careful when pulling out the cutter blade, it is very sharp.
    • The Brother no. TL 5 Cutter Blade Unit is required for replacement.
Conclusione
Haley Sweet
Membro da: 10/30/14
460 Reputazione
4 Guide realizzate
Baylor, Team 4-4, Williams Fall 2014 Membro di Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,322
