Salta al contenuto principale
Brother PT-1010 Battery Replacement
  1. Brother PT-1010 Battery Replacement, Removing Back Panel: passo 1, immagine 1 di 1
    • Turn device so you are looking down at the top
  2. Brother PT-1010 Battery Replacement: passo 2, immagine 1 di 2 Brother PT-1010 Battery Replacement: passo 2, immagine 2 di 2
    • Press firmly on arrow indicator and pull panel toward you.
  3. Brother PT-1010 Battery Replacement, Remove Dead Batteries: passo 3, immagine 1 di 1
    • Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
    • Make sure the battery compartment is empty and clear of debris.
  4. Brother PT-1010 Battery Replacement: passo 4, immagine 1 di 2 Brother PT-1010 Battery Replacement: passo 4, immagine 2 di 2
    • Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment.
    • Do the same thing to insert the next 2 batteries.
  5. Brother PT-1010 Battery Replacement: passo 5, immagine 1 di 1
    • The next 3 batteries will be inserted on top of the others.
    • Insert the 4th battery with the flat side (indicated by the - symbol on the battery) facing to the right of the battery compartment.
  6. Brother PT-1010 Battery Replacement: passo 6, immagine 1 di 1
    • Repeat step 5 to insert the last 2 batteries.
  7. Brother PT-1010 Battery Replacement, Replace Back Panel: passo 7, immagine 1 di 1
    • Reinsert back panel.
Conclusione
Haley Sweet
Membro da: 10/30/14
460 Reputazione
4 Guide realizzate
Baylor, Team 4-4, Williams Fall 2014 Membro di Baylor, Team 4-4, Williams Fall 2014
BU-WILLIAMS-F14S4G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,797
