Introduzione
Replacing the On/Off switch should the wiring become faulty.
Cosa ti serve
Use a Phillips #0 screwdriver to remove the following ten screws:
Four 18mm Phillips screws.
Four 9.75mm Phillips screws.
Two 8mm Phillips screws.
Use a Phillips #0 screwdriver to remove the following six screws:
Six 14.5mm Phillips screws.
Remove the power cord from the groove. (the black cord that leads into the green wire.)
Altre 2 persone hanno completato questa guida.
2 Commenti
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
