Salta al contenuto principale
Braun Aromaster KF440 Base Replacement
Cosa ti serve
  1. Braun Aromaster KF440 Base Replacement, Access the base: passo 1, immagine 1 di 1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 Base Replacement, Remove the nut: passo 2, immagine 1 di 1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 Base Replacement, Remove the cover: passo 3, immagine 1 di 1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
Conclusione
Darcy Groom
Membro da: 10/19/14
343 Reputazione
3 Guide realizzate
Baylor, Team 8-12, Williams Fall 2014 Membro di Baylor, Team 8-12, Williams Fall 2014
BU-WILLIAMS-F14S8G12
3 Membri
10 Guide realizzate
2 Commenti
Can’t remove nut. Soooo small. Plus, clockwise… Or counter clockwise?
Bobbie Savitz - Replica
Das Problem istnicht die das Entfernen der Mutter wie beschrieben, sondern die Schraube die nur mit einem Spezial-Schraubenzieher geloesst werden kann. Und den gibts nicht zu kaufen. Oder?
Udo Doerge - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,076
