Salta al contenuto principale
Bottom Board Removal
Cosa ti serve
  1. Bottom Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: passo 1, immagine 1 di 1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Bottom Board Removal: passo 2, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Bottom Board Removal: passo 3, immagine 1 di 3 Bottom Board Removal: passo 3, immagine 2 di 3 Bottom Board Removal: passo 3, immagine 3 di 3
    • Grab the top shell of the mouse and lift up to remove.
  4. Bottom Board Removal: passo 4, immagine 1 di 1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Bottom Board Removal: passo 5, immagine 1 di 2 Bottom Board Removal: passo 5, immagine 2 di 2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Bottom Board Removal, Side Panels: passo 6, immagine 1 di 2 Bottom Board Removal, Side Panels: passo 6, immagine 2 di 2
    • Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver.
  7. Bottom Board Removal: passo 7, immagine 1 di 2 Bottom Board Removal: passo 7, immagine 2 di 2
    • Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail.
  8. Bottom Board Removal: passo 8, immagine 1 di 3 Bottom Board Removal: passo 8, immagine 2 di 3 Bottom Board Removal: passo 8, immagine 3 di 3
    • Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse.
  9. Bottom Board Removal: passo 9, immagine 1 di 2 Bottom Board Removal: passo 9, immagine 2 di 2
    • Grab the sides of the mouse and lift them up to detach from the base of the mouse.
  10. Bottom Board Removal, Bottom Board: passo 10, immagine 1 di 2 Bottom Board Removal, Bottom Board: passo 10, immagine 2 di 2
    • Pop the scroll wheel out of the snap holding it in place. You can use your finger or a spudger to do so.
  11. Bottom Board Removal: passo 11, immagine 1 di 2 Bottom Board Removal: passo 11, immagine 2 di 2
    • Locate the four 5 mm black flat head screws on the corners of the bottom board.
    • Unscrew these four black screws.
  12. Bottom Board Removal: passo 12, immagine 1 di 3 Bottom Board Removal: passo 12, immagine 2 di 3 Bottom Board Removal: passo 12, immagine 3 di 3
    • Lift the bottom board up to remove from its mounting posts. This will separate it completely from the bottom panel of the mouse.
Conclusione
Altre 2 persone hanno completato questa guida.
royceeklund
Membro da: 01/18/13
79 Reputazione
3 Guide realizzate
Cal Poly, Team 18-36, Regan Winter 2013 Membro di Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Membri
30 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 36
Tutti i Tempi: 5,177
