Salta al contenuto principale
Blu Studio HD 6.0 Microphone Replacement
Cosa ti serve
  1. Blu Studio HD 6.0 Microphone Replacement, Rear Case: passo 1, immagine 1 di 1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Microphone Replacement, Back Panel.: passo 2, immagine 1 di 2 Blu Studio HD 6.0 Microphone Replacement, Back Panel.: passo 2, immagine 2 di 2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Microphone Replacement: passo 3, immagine 1 di 2 Blu Studio HD 6.0 Microphone Replacement: passo 3, immagine 2 di 2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Microphone Replacement, Midframe: passo 4, immagine 1 di 2 Blu Studio HD 6.0 Microphone Replacement, Midframe: passo 4, immagine 2 di 2
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Microphone Replacement: passo 5, immagine 1 di 1
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Microphone Replacement: passo 6, immagine 1 di 1
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Microphone Replacement: passo 7, immagine 1 di 1
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
  8. Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: passo 8, immagine 1 di 2 Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: passo 8, immagine 2 di 2
    • The microphone is located at the rear-lower-left corner.
  9. Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: passo 9, immagine 1 di 2 Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: passo 9, immagine 2 di 2
    • Lift the microphone very carefully.
    • Unsolder the two lower wires ( one red wire and one black wire ).
  10. Blu Studio HD 6.0 Microphone Replacement, Solder the new microphone.: passo 10, immagine 1 di 1
    • Solder the new microphone in the same spot. The black wire will go in the lower spot and the red wire in the upper spot.
Conclusione
Altre 6 persone hanno completato questa guida.
Ernesto Diaz
Membro da: 09/23/14
1.759 Reputazione
3 Guide realizzate
USF Tampa, Team 9-1, Blackwell Fall 2014 Membro di USF Tampa, Team 9-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G1
3 Membri
8 Guide realizzate
2 Commenti
Where can I get a blue microphone for my BLU phone. When I answer my BLU phone I can't hear the person on the other line but they cannot hear me so I believe it's just my microphone when I speak.
Christina - Replica
Where can I buy microphones
b langdon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 13
Tutti i Tempi: 13,597
