Introduzione
This guide will describe how to take apart the Blu Studio 5.5 S to access the phone's speaker.
In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
Aggiungi Commento
Place your finger in the small notch on the left side of the charging port (facing from the back). Once your finger is in the notch, pull the back case towards yourself to remove it. Once your finger is in the notch, pull the back case towards yourself to remove it.
  • Place your finger in the small notch on the left side of the charging port (facing from the back).
  • Once your finger is in the notch, pull the back case towards yourself to remove it.
the phone i purchased does not have a notch that you described and the camera lens is in the middle and the flash is beneath
DAVID A WALKER - Replica
it is impossible to open without damaging case (which I already did) . why don't these idiots provide a usable manual with their product? we aren't all mind readers
Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it. Insert your finger into the notch near the lower left of the battery, apply pressure and lift up. Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
  • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
  • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
put thewholeentire battery in garbage and it will charge up ur battery and it worked perfectly me contact me at 216-564-1274 if anything else happends
NANA - Replica
Put battery in garbage? ? What kind??? My trash?? Help
rocky14 -
i try to take it out to reset the phone now it is not coming back on help please
tiffanymorris52 - Replica
The speaker is located behind the inner back case.  Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws. Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom. Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
  • The speaker is located behind the inner back case. Using a Phillips #0 screwdriver, unscrew the 10, 7mm screws.
  • Using the Phillips #00 screwdriver, unscrew the two, 10mm screws at the bottom.
Aggiungi Commento
Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
  • Apply pressure and pop off the bottom aesthetic case, being careful not to break it.
Aggiungi Commento
Use the Spudger to pop the inner back casing off.  Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case. Pick up the inner back case and flip it over. Pick up the inner back case and flip it over.
  • Use the Spudger to pop the inner back casing off. Do this by lightly raising the side of the battery housing, then sliding the Spudger around the case.
  • Pick up the inner back case and flip it over.
Aggiungi Commento
The speaker is located on the bottom of the back inner case. To remove it, use a pair of angled tweezers. Use the tweezers to remove the speaker off of the casing. Only put the tweezers in enough to gain leverage.
  • The speaker is located on the bottom of the back inner case. To remove it, use a pair of angled tweezers.
  • Use the tweezers to remove the speaker off of the casing.
  • Only put the tweezers in enough to gain leverage.
Aggiungi Commento
Conclusione
Cody Dyl
Membro da: 27/10/2014
744 Reputazione
5 Guide realizzate
UMass Dartmouth, Team 4-8, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-8, Miles Fall 2014
UMASSD-MILES-F14S4G8
2 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,059
