Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
  • Remove the back cover by lifting at the notch towards the bottom of the phone. Use your fingernail to pry up.
Aggiungi Commento
Use one hand to pull the cover up, and the other hand to hold the phone down.
  • Use one hand to pull the cover up, and the other hand to hold the phone down.
Aggiungi Commento
Pull the battery up from the lower left corner.
  • Pull the battery up from the lower left corner.
Aggiungi Commento
Now, you can put the new battery in, then replace the cover.
  • Now, you can put the new battery in, then replace the cover.
Aggiungi Commento
Conclusione
Julio
Membro da: 25/10/2014
695 Reputazione
6 Guide realizzate
Gateway, Team 1-5, Johnson Fall 2014 Membro di Gateway, Team 1-5, Johnson Fall 2014
GCC-JOHNSON-F14S1G5
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 441
