Introduzione
Outline what you are going to teach someone how to do.
Parti
Nessuna parte richiesta.
Find the small slot on the bottom left corner of the back panel.
  • Find the small slot on the bottom left corner of the back panel.
  • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
  • When the back panel is loose enough, use your fingers to remove it completely.
If slot 1 is messed up can you use slot 2 for simcard and the phone still work
Margie White - Replica
With the back panel off, you should see a large white rectangle.  This is the battery.  Slide the spudger under the indent on the bottom right of the battery and pull it up.
  • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Dashaya Toney
Membro da: 27/10/2014
876 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 4-7, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-7, Miles Fall 2014
UMASSD-MILES-F14S4G7
3 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,575
