Salta al contenuto principale
Blackberry Curve 8330 Track Ball Replacement
Cosa ti serve
  1. Blackberry Curve 8330 Track Ball Replacement, Remove Back Cover: passo 1, immagine 1 di 1
    • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
    • Hold the phone with the back side facing you.
    • Press down on the silver tab towards the bottom end of the phone.
    • Carefully lift up the back casing to reveal the battery.
  2. Blackberry Curve 8330 Track Ball Replacement, Remove Battery: passo 2, immagine 1 di 1
    • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
    • The phone should now look like this.
  3. Blackberry Curve 8330 Track Ball Replacement, Keyboard: passo 3, immagine 1 di 1
    • Remove the two top screws using a T5 Torx screwdriver.
  4. Blackberry Curve 8330 Track Ball Replacement: passo 4, immagine 1 di 2 Blackberry Curve 8330 Track Ball Replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose.
    • The cover will now pull off easily.
  5. Blackberry Curve 8330 Track Ball Replacement: passo 5, immagine 1 di 2 Blackberry Curve 8330 Track Ball Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to pry between the front and back cover.
    • Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
    • There are 5 securing clips on the front panel to disconnect.
    • Pry gently to prevent breaking the plastic clips when removing the front panel.
    • Once all the clips have been freed, the front cover will lift away from the phone.
  6. Blackberry Curve 8330 Track Ball Replacement: passo 6, immagine 1 di 1
    • Lift the flexible keypad away from the device. It should come off easily.
  7. Blackberry Curve 8330 Track Ball Replacement: passo 7, immagine 1 di 2 Blackberry Curve 8330 Track Ball Replacement: passo 7, immagine 2 di 2
    • Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing.
    • Lift the keyboard frame away from the device.
    • There may be a small amount of adhesive at the bottom of the frame that needs to be pulled away.
  8. Blackberry Curve 8330 Track Ball Replacement, Track Ball: passo 8, immagine 1 di 1
    • Use a plastic opening tool to pry the trackball housing from the keyboard housing.
  9. Blackberry Curve 8330 Track Ball Replacement: passo 9, immagine 1 di 1
    • Remove the trackball from the silver trackball housing by hand.
Conclusione
Nhan Le
Membro da: 04/03/12
27 Reputazione
1 Guida realizzata
Cal Poly, Team 14-11, Forte Spring 2012 Membro di Cal Poly, Team 14-11, Forte Spring 2012
CPSU-FORTE-S12S14G11
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,313
