We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
  • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
  • Hold the phone with the back side facing you.
  • Press down on the silver tab towards the bottom end of the phone.
  • Carefully lift up the back casing to reveal the battery.
Aggiungi Commento
Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
  • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
  • The phone should now look like this.
Aggiungi Commento
Remove the two top screws using a T5 Torx screwdriver.
  • Remove the two top screws using a T5 Torx screwdriver.
Aggiungi Commento
Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose. The cover will now pull off easily.
  • Use a plastic opening tool to pry the edges of the bottom cover until it snaps loose.
  • The cover will now pull off easily.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Use a plastic opening tool to pry between the front and back cover. Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
  • Use a plastic opening tool to pry between the front and back cover.
  • Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
  • There are 5 securing clips on the front panel to disconnect.
  • Pry gently to prevent breaking the plastic clips when removing the front panel.
  • Once all the clips have been freed, the front cover will lift away from the phone.
Aggiungi Commento
Lift the flexible keypad away from the device. It should come off easily.
  • Lift the flexible keypad away from the device. It should come off easily.
Aggiungi Commento
Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing. Lift the keyboard frame away from the device.
  • Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing.
  • Lift the keyboard frame away from the device.
  • There may be a small amount of adhesive at the bottom of the frame that needs to be pulled away.
Aggiungi Commento
Detach each side casing by pulling them off gently from the phone. Detach each side casing by pulling them off gently from the phone.
  • Detach each side casing by pulling them off gently from the phone.
Aggiungi Commento
Remove the back housing from the mother board.
  • Remove the back housing from the mother board.
Aggiungi Commento
Unhook the screen frame from the small tab at the top of the motherboard.
  • Unhook the screen frame from the small tab at the top of the motherboard.
Aggiungi Commento
Using a plastic opening tool, detach the connector on the LCD screen from the motherboard. There may be some adhesive behind the LCD screen. If needed, pry the LCD screen away from the motherboard using the plastic opening tool.
  • Using a plastic opening tool, detach the connector on the LCD screen from the motherboard.
  • There may be some adhesive behind the LCD screen. If needed, pry the LCD screen away from the motherboard using the plastic opening tool.
  • Remove the LCD screen from the motherboard
Aggiungi Commento
Conclusione
Joshua Ramos
Membro da: 04/04/2012
65 Reputazione
2 Guide realizzate
Cal Poly, Team 14-11, Forte Spring 2012 Membro di Cal Poly, Team 14-11, Forte Spring 2012
CPSU-FORTE-S12S14G11
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,109
