Introduzione
This guide will show you how to:
  • Remove the battery
  • Remove the front panel
  • Replace the speaker
Parti
Nessuna parte richiesta.
Hold the phone with the back facing you. Press the silver tab down and remove the cover.
  • Hold the phone with the back facing you.
  • Press the silver tab down and remove the cover.
Aggiungi Commento
Pull up on the top edge of the battery to remove it.
  • Pull up on the top edge of the battery to remove it.
Aggiungi Commento
Use a plastic opening tool to gently pry the bottom cover loose. Do not use excessive force at risk of damaging the antenna, which is under this casing. Pull the cover from the front of the phone after the back is loose.
  • Use a plastic opening tool to gently pry the bottom cover loose.
  • Do not use excessive force at risk of damaging the antenna, which is under this casing.
  • Pull the cover from the front of the phone after the back is loose.
Aggiungi Commento
Remove the two top screws with a T5 Torx screwdriver. The screws are 8mm long.
  • Remove the two top screws with a T5 Torx screwdriver.
  • The screws are 8mm long.
Aggiungi Commento
Gently pry off the top of the side casings. The side casings cannot be fully removed yet because they are screwed on at the bottom.
  • Gently pry off the top of the side casings.
  • The side casings cannot be fully removed yet because they are screwed on at the bottom.
Aggiungi Commento
Use a plastic opening tool to detach the securing clips holding the the front panel in place.
  • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
  • There are six securing clips total.
Aggiungi Commento
Remove the front panel.
  • Remove the front panel.
  • You may need to apply some force because the front panel is attached to the rest of the device with adhesive.
Aggiungi Commento
Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame. The screws are 6mm long. The screws are 6mm long.
  • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
  • The screws are 6mm long.
Aggiungi Commento
After the bottom two screws have been removed the side casings can be removed. After the bottom two screws have been removed the side casings can be removed.
  • After the bottom two screws have been removed the side casings can be removed.
Aggiungi Commento
Remove the back case. The speaker is located on the back case. The speaker is located on the back case.
  • Remove the back case.
  • The speaker is located on the back case.
Aggiungi Commento
Conclusione
Cal Poly, Team 3-6, Regan Fall 2011 Membro di Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,887
