Salta al contenuto principale
Blackberry Bold 9650 Buzzer-Loundspeaker Replacement
Cosa ti serve
  1. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Battery: passo 1, immagine 1 di 2 Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: passo 2, immagine 1 di 1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, SIM Card: passo 3, immagine 1 di 1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: passo 4, immagine 1 di 1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Back Chassis: passo 5, immagine 1 di 1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: passo 6, immagine 1 di 1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: passo 7, immagine 1 di 1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement: passo 8, immagine 1 di 1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  9. Blackberry Bold 9650 Buzzer-Loundspeaker Replacement, Buzzer-Loundspeaker: passo 9, immagine 1 di 1
    • Use a plastic pry tool to remove the speaker.
    • Be careful removing removing the speaker as the plastic frame around the speaker is fragile.
Conclusione
Ryan
Membro da: 03/12/12
696 Reputazione
11 Guide realizzate
Clemson, Team 2-5, Benson Spring 2012 Membro di Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 3,975
