Salta al contenuto principale
Blackberry Bold 9000 Volume Toggle Replacement
Cosa ti serve
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: passo 1, immagine 1 di 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Volume Toggle Replacement: passo 2, immagine 1 di 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Volume Toggle Replacement: passo 3, immagine 1 di 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: passo 4, immagine 1 di 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Volume Toggle Replacement: passo 5, immagine 1 di 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Volume Toggle Replacement: passo 6, immagine 1 di 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: passo 7, immagine 1 di 1
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Volume Toggle Replacement: passo 8, immagine 1 di 1
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Blackberry Bold 9000 Volume Toggle Replacement: passo 9, immagine 1 di 1
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
Conclusione
Altre 2 persone hanno completato questa guida.
Kelly
Membro da: 01/18/12
566 Reputazione
6 Guide realizzate
Cal Poly, Team 8-17, Maness Winter 2012 Membro di Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,442
