Salta al contenuto principale
Blackberry Bold 9000 LCD Screen Replacement
Cosa ti serve
  1. Blackberry Bold 9000 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 LCD Screen Replacement: passo 3, immagine 1 di 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 LCD Screen Replacement, Rear Case: passo 4, immagine 1 di 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 LCD Screen Replacement, LCD Screen: passo 7, immagine 1 di 1
    • With the same plastic opening tool, lift the motherboard up and out.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Using a spudger, lift the ribbon band in the upper right-hand corner up and away from the motherboard assembly until it disconnects.
  9. Blackberry Bold 9000 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Turn the motherboard assembly over.
    • Starting at the lower corners of the screen, begin to lift the screen away from the motherboard using the spudger.
    • Do this step very slowly to avoid breaking the screen or the motherboard. The backing will eventually separate.
    • Remove the plastic bit that hides the speaker grill - it is stuck with double-sided tape.
    • With a thin blade/pin, ease the speaker grill and the metal plate away from the old lcd screen.
Conclusione
Altre 8 persone hanno completato questa guida.
Kelly
Membro da: 01/18/12
566 Reputazione
6 Guide realizzate
Cal Poly, Team 8-17, Maness Winter 2012 Membro di Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 7,524
