Salta al contenuto principale
Blackberry 8700c Battery Replacement
  1. Blackberry 8700c Battery Replacement, Battery: passo 1, immagine 1 di 3 Blackberry 8700c Battery Replacement, Battery: passo 1, immagine 2 di 3 Blackberry 8700c Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the back cover by pushing the button near the bottom of the phone and sliding the cover off.
  2. Blackberry 8700c Battery Replacement: passo 2, immagine 1 di 2 Blackberry 8700c Battery Replacement: passo 2, immagine 2 di 2
    • Using your fingernail, remove the battery by pulling on the notch on the top-right of the battery.
    • If you are not installing a new battery, move on to the next step. If you are installing a new battery, read on.
    • Install the new battery by first placing the bottom end of the battery in the phone and then pushing the battery into place.
Conclusione
To reassemble your Blackberry 8700c, follow these instructions in reverse order.
k3nt
Membro da: 10/28/09
42 Reputazione
4 Guide realizzate
Cal Poly, Team 18-4, Maness Fall 2009 Membro di Cal Poly, Team 18-4, Maness Fall 2009
CPSU-MANESS-F09S18G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,828
