Introduzione
If the rear speaker on your Blackberry 7520 is broken, look here to install a new one.
Parti
Nessuna parte richiesta.
Turn the phone upside down. Push down on the black button on the back of the phone to slide the rear panel off.
  • Turn the phone upside down.
  • Push down on the black button on the back of the phone to slide the rear panel off.
  • The battery should be visible now.
Aggiungi Commento
Hold the BlackBerry in one hand face-up with the screen facing towards you. Gently smack the phone against your hand to dislodge the battery. Gently smack the phone against your hand to dislodge the battery.
  • Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Gently smack the phone against your hand to dislodge the battery.
Aggiungi Commento
Use a T6 Torx screwdriver to remove the six screws located on the rear of the phone. Use a T6 Torx screwdriver to remove the six screws located on the rear of the phone.
  • Use a T6 Torx screwdriver to remove the six screws located on the rear of the phone.
Aggiungi Commento
Spedizione gratuita su tutti gli ordini da 79,00 US$ in su.
Sfoglia il Nostro Negozio
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Use a pick or plastic iPod opening tool to push the clips, that are holding the rear casing. Apply a firm pressure at a forty-five degree angle to dislodge the clips. Applying too much pressure could break the plastic clips and permanently damage the casing, so be careful.
  • Use a pick or plastic iPod opening tool to push the clips, that are holding the rear casing. Apply a firm pressure at a forty-five degree angle to dislodge the clips.
  • Applying too much pressure could break the plastic clips and permanently damage the casing, so be careful.
Aggiungi Commento
Repeat the  process of unlatching the clips for the top section of the Blackberry.
  • Repeat the process of unlatching the clips for the top section of the Blackberry.
Aggiungi Commento
Do not try to pull the two pieces apart. You may tear the antenna cable.  Instead, fold the two pieces open to avoid stress on the cable.
  • Do not try to pull the two pieces apart. You may tear the antenna cable. Instead, fold the two pieces open to avoid stress on the cable.
Aggiungi Commento
Separating the two halves allows you to access the speaker. Which is located in the front half of the case.
  • Separating the two halves allows you to access the speaker. Which is located in the front half of the case.
Aggiungi Commento
Insert a plastic opening tool between the speaker and the case. Then pry the speaker out. To reinsert the speaker, align the blue notch to the blue stud. Then the red notch to the red stud. As shown in the last picture. To reinsert the speaker, align the blue notch to the blue stud. Then the red notch to the red stud. As shown in the last picture.
  • Insert a plastic opening tool between the speaker and the case. Then pry the speaker out.
  • To reinsert the speaker, align the blue notch to the blue stud. Then the red notch to the red stud. As shown in the last picture.
Aggiungi Commento
Conclusione
Nathan
Membro da: 18/01/2010
31 Reputazione
7 Guide realizzate
Cal Poly, Team 5-7, Forte Winter 2010 Membro di Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,372
