Introduzione
This guide will allow the user to replace the speaker.
Parti
Nessuna parte richiesta.
With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
Aggiungi Commento
Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
Aggiungi Commento
Remove the battery by pushing against it from the right and then pulling towards you.
  • Remove the battery by pushing against it from the right and then pulling towards you.
Aggiungi Commento
Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
Aggiungi Commento
Use a plastic opening tool or your fingernails to remove the plastic backing. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  • Use a plastic opening tool or your fingernails to remove the plastic backing.
  • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
Aggiungi Commento
Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
  • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
  • Place the four screws released from the phone in a plastic bag.
Aggiungi Commento
The black battery casing and logic board can now be separated for the following steps.
  • The black battery casing and logic board can now be separated for the following steps.
Aggiungi Commento
With the speaker facing towards you, use a spudger to unfasten the three clips indicated in the picture. Place the three clips in plastic bag and set aside.
  • With the speaker facing towards you, use a spudger to unfasten the three clips indicated in the picture.
  • Place the three clips in plastic bag and set aside.
  • Once clips are removed, you will have full access to remove the speaker.
Aggiungi Commento
Conclusione
CeeJay
Membro da: 28/10/2009
19 Reputazione
5 Guide realizzate
Cal Poly, Team 9-17, Regan Fall 2009 Membro di Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,107
