Before beginning this installation, make sure phone is powered off . Turn phone over to the backside. Press down on the lower portion of the back cover.
  • Before beginning this installation, make sure phone is powered off .
  • Turn phone over to the backside.
  • Press down on the lower portion of the back cover.
  • Slide the lower portion down to remove the cover and reveal the battery.
Aggiungi Commento
Remove the battery from the phone.
  • Remove the battery from the phone.
Aggiungi Commento
Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver. Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
  • Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
Aggiungi Commento
Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool. Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool. Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
  • Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
Aggiungi Commento
Remove the back casing using the Plastic Opening Tool Once the back casing is removed the top two buttons are likely to pop out.
  • Remove the back casing using the Plastic Opening Tool
    • Once the back casing is removed the top two buttons are likely to pop out.
Aggiungi Commento
Locate the two 9.2mm screws on the upper inside casing Remove them using the T4 Torx Screwdriver Slide off the front casing once the screws are removed.
  • Locate the two 9.2mm screws on the upper inside casing
  • Remove them using the T4 Torx Screwdriver
  • Slide off the front casing once the screws are removed.
    • Trackball will fall out once the casing is removed.
Aggiungi Commento
Once the microphone is revealed, use the flathead screwdriver, or the tip of a knife, to carefully pry the microphone out of the hole. Be careful not to bend the ring around the microphone when prying it out. If the ring does get bent you may not be able to replace the microphone.
  • Once the microphone is revealed, use the flathead screwdriver, or the tip of a knife, to carefully pry the microphone out of the hole.
    • Be careful not to bend the ring around the microphone when prying it out. If the ring does get bent you may not be able to replace the microphone.
Aggiungi Commento
Conclusione
tbace
Membro da: 18/04/2012
19 Reputazione
2 Guide realizzate
Cal Poly, Team 17-27, Amido Spring 2012 Membro di Cal Poly, Team 17-27, Amido Spring 2012
CPSU-AMIDO-S12S17G27
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 684
