Introduzione
Need to get inside your Blackberry Storm to fix it? Or just want to salvage parts? This is an easy to follow guide to do it!
Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
  • Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
Aggiungi Commento
Turn your Storm where the battery door is facing up. Remove the battery door. Remove the battery.
  • Turn your Storm where the battery door is facing up.
  • Remove the battery door.
  • Remove the battery.
Aggiungi Commento
Remove the two hex screws as shown by the SIM card slot.
  • Remove the two hex screws as shown by the SIM card slot.
Aggiungi Commento
Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool. Remove the two hex screws underneath it.
  • Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
  • Remove the two hex screws underneath it.
Aggiungi Commento
Turn the phone over and remove the plastic cover under the buttons as shown. Remove the 2 screws underneath. Remove the 2 screws underneath.
  • Turn the phone over and remove the plastic cover under the buttons as shown.
  • Remove the 2 screws underneath.
Aggiungi Commento
Go around your device with the plastic pry tool, there a 3 clips on each side of the housing. There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself. There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
  • Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
  • There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
Aggiungi Commento
You now have 3 pieces. The rear, mid , & front housing.
  • You now have 3 pieces. The rear, mid , & front housing.
Aggiungi Commento
To remove the screen gently pry up this ribbon cable with a pry tool. To remove the screen gently pry up this ribbon cable with a pry tool.
  • To remove the screen gently pry up this ribbon cable with a pry tool.
Aggiungi Commento
To remove the main board from the mid housing disconnect the ribbon cable as pictured. Now follow in reverse order for reassembly! Now follow in reverse order for reassembly!
  • To remove the main board from the mid housing disconnect the ribbon cable as pictured.
  • Now follow in reverse order for reassembly!
Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Josh Forester
Membro da: 28/11/2010
2.294 Reputazione
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 9,349
