Salta al contenuto principale
BlackBerry Curve 8900 Microphone Replacement
Cosa ti serve
  1. BlackBerry Curve 8900 Microphone Replacement, Microphone: passo 1, immagine 1 di 1
    • Press and slide the battery cover from the back of the device with your fingers.
    • Remove the battery by pulling it out.
    • The battery is shown outside of the device on the right side of the photograph, "BlackBerry D-X18."
  2. BlackBerry Curve 8900 Microphone Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    iFixit Opening Tool
    $1.99
    Compra
    • Using the iFixit Opening Tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Microphone Replacement: passo 3, immagine 1 di 1
    T6 Torx Screwdriver
    $9.99
    Compra
  4. BlackBerry Curve 8900 Microphone Replacement: passo 4, immagine 1 di 1
    iFixit Opening Tool
    $1.99
    Compra
  5. BlackBerry Curve 8900 Microphone Replacement: passo 5, immagine 1 di 2 BlackBerry Curve 8900 Microphone Replacement: passo 5, immagine 2 di 2
    • Work your way around the case, slowly, prying the back of the plastic tabs until the motherboard comes free.
  6. BlackBerry Curve 8900 Microphone Replacement: passo 6, immagine 1 di 1
    • With your fingers, carefully remove the screen so as not to damage it.
  7. BlackBerry Curve 8900 Microphone Replacement: passo 7, immagine 1 di 2 BlackBerry Curve 8900 Microphone Replacement: passo 7, immagine 2 di 2
    • With your fingers, carefully unhook the antenna cable in all three locations.
  8. BlackBerry Curve 8900 Microphone Replacement: passo 8, immagine 1 di 1
    Spudger
    $3.99
    Compra
    • Detach the ribbon cable on the front of the motherboard using the Spudger tool.
  9. BlackBerry Curve 8900 Microphone Replacement: passo 9, immagine 1 di 1
    • Detach the motherboard from both ribbon connections.
    • The ribbon connections are indicated by red circles on the photograph.
    • The ribbon connections are indicated by orange rectangles on the photograph.
  10. BlackBerry Curve 8900 Microphone Replacement: passo 10, immagine 1 di 2 BlackBerry Curve 8900 Microphone Replacement: passo 10, immagine 2 di 2
    • Replace the entire motherboard to replace the microphone.
Conclusione
Johnny Tran
Membro da: 09/10/11
473 Reputazione
4 Guide realizzate
Cuesta, Team 1-3, Zipperian Fall 2011 Membro di Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,455
