Salta al contenuto principale
BlackBerry Curve 8900 Keypad Replacement
Cosa ti serve
  1. BlackBerry Curve 8900 Keypad Replacement, Remove the battery: passo 1, immagine 1 di 1
    • Remove the back cover and the battery from the device.
  2. BlackBerry Curve 8900 Keypad Replacement, Remove the protective cover: passo 2, immagine 1 di 1
    • 4 screws should be visible. Pry off the lower portion of the back to reveal all 6 screws.
  3. BlackBerry Curve 8900 Keypad Replacement, Remove the screws from the midframe: passo 3, immagine 1 di 1
    • Remove all six T6 screws from the midframe.
  4. BlackBerry Curve 8900 Keypad Replacement, Split apart the device: passo 4, immagine 1 di 1
    • Separate the midframe from the rest of the device.
  5. BlackBerry Curve 8900 Keypad Replacement, Remove the motherboard: passo 5, immagine 1 di 1
    • Gently pry back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case prying the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
  6. BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: passo 6, immagine 1 di 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: passo 6, immagine 2 di 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: passo 6, immagine 3 di 3
    • Lift the keypad from the motherboard.
    • When replacing the keypad, be sure that the navigation ball is in its original position.
Conclusione
Altre 3 persone hanno completato questa guida.
Cuesta, Team 1-3, Zipperian Fall 2011 Membro di Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 6,983
