Introduzione
Your work area should be clean, lint-free, and with adequate lighting to visualize small print or parts.
The keypad and navigation ball may become loose and fall away from the motherboard, use caution so these items are not lost or damaged.
Cosa ti serve
Using a small plastic opening tool, remove the lower rear cover.
Gently pry the back the plastic tabs that secure the motherboard to the case.
Slowly work your way around the case with the tabs until the motherboard comes free.
Remove the motherboard.
Use the new case and reassemble the phone by doing the instructions in reverse order.
Altre 2 persone hanno completato questa guida.
