Introduzione
Few tools are required to do this.
A small plastic pry tool or even a fingernail is sufficient. Working area surface should be clean and dry with adequate lighting.
Immediately wash hands after handling the battery and completing the process. Discard the dead battery properly.
Pry off the back and separate it from the front of the phone case. You will see the battery once the cover is removed.
  • Pry off the back and separate it from the front of the phone case. You will see the battery once the cover is removed.
Pry off the back and separate it from the front of the phone case. You should see the battery once you pry the back off.
(rewriting the second sentence)
Aubrey - Replica
On both sides of the battery, there is a lighter grey half-circle. This is the best place to use your fingers to gently lift the battery free of the housing. Set aside the old battery, then replace it with the new battery. It should easily fit into place. Replace backing of phone, pressing gently to secure to back of phone case
  • On both sides of the battery, there is a lighter grey half-circle. This is the best place to use your fingers to gently lift the battery free of the housing. Set aside the old battery, then replace it with the new battery. It should easily fit into place.
  • Replace backing of phone, pressing gently to secure to back of phone case
(deleted "it sits in") from second sentence
Aubrey - Replica
Replace backing of phone, pressing gently to secure to back of phone case ( There seems to be a bit of repetition in this sentence so I rewrote it.)
Reattach the back cover by pressing gently until cover is secure.
Aubrey - Replica
Conclusione
Renae Bishop
Membro da: 07/09/2011
66 Reputazione
4 Guide realizzate
Cuesta, Team 1-3, Zipperian Fall 2011 Membro di Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,617
