Place the phone on a flat surface with the screen facing down. Remove the plastic backplate by pulling up on the bottom of the cover.
  • Place the phone on a flat surface with the screen facing down.
  • Remove the plastic backplate by pulling up on the bottom of the cover.
Aggiungi Commento
Remove the battery by pulling up from the top of the battery.
  • Remove the battery by pulling up from the top of the battery.
Aggiungi Commento
Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver. Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
  • Remove the two screws midway up the phone on the left and right sides using a T6 Torx Screwdriver.
  • Warning: One screw will have warranty tape covering the screw. Removing this screw will likely void the phones warranty.
Aggiungi Commento
Flip the phone over so the keyboard faces up. Insert a plastic spudger into the screen where speaker resides.
  • Flip the phone over so the keyboard faces up.
  • Insert a plastic spudger into the screen where speaker resides.
  • I recommend going from the side. There are two layers to the cover. You need to make sure you get underneath the bottom layer if you plan on reusing this cover.
  • Gently lift up plastic screen cover until screen cover separates from screen.
  • Continue until screen cover is completely removed.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up. Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed. Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
  • Insert the spudger into the top of the plastic siding on the front of the phone and lift up until the siding lifts up.
  • Slide the tool around the entire perimeter of the phone until the plastic siding is completely removed.
Aggiungi Commento
The keyboard should slide off of the phone now that the plastic siding has been removed. The keyboard should slide off of the phone now that the plastic siding has been removed.
  • The keyboard should slide off of the phone now that the plastic siding has been removed.
Aggiungi Commento
To detach the screen, there are two screws at the top of the phone to be removed.  Use the T6 Torx Screwdriver to remove the screws. There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone. Note: When reassembling, the ribbon should be reattached before replacing the top screws.
  • To detach the screen, there are two screws at the top of the phone to be removed. Use the T6 Torx Screwdriver to remove the screws.
  • There is a gold ribbon on the top left of the phone. Lift up this ribbon gently until it is detached from the phone.
    • Note: When reassembling, the ribbon should be reattached before replacing the top screws.
Aggiungi Commento
There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen. Use pressure to unlatch the screen from the clips. Now that these clips have been undone, the screen should lift up easily.
  • There are two clips on each side of the phone. Insert a plastic spudger between the clips and the screen.
  • Use pressure to unlatch the screen from the clips.
  • Now that these clips have been undone, the screen should lift up easily.
Aggiungi Commento
Now there are four screws that need to be removed. They are located at the bottom of the phone and can also be removed using a T6 Torx Screwdriver. Now there are four screws that need to be removed. They are located at the bottom of the phone and can also be removed using a T6 Torx Screwdriver.
  • Now there are four screws that need to be removed. They are located at the bottom of the phone and can also be removed using a T6 Torx Screwdriver.
Aggiungi Commento
Now the motherboard will lift up out of the plastic backing of the phone. Now the motherboard will lift up out of the plastic backing of the phone. Now the motherboard will lift up out of the plastic backing of the phone.
  • Now the motherboard will lift up out of the plastic backing of the phone.
Aggiungi Commento
Flip over the motherboard. There is another torx screw near the middle of the motherboard on the left side. Using the T5 Torx Screwdriver, remove the screw and the metal casing.
  • Flip over the motherboard.
  • There is another torx screw near the middle of the motherboard on the left side.
  • Using the T5 Torx Screwdriver, remove the screw and the metal casing.
    • Note: Distinguish this screw from the others for reassembly purposes.
  • Detach the clip holding the track pad in.
Aggiungi Commento
Remove the trackpad from the motherboard.
  • Remove the trackpad from the motherboard.
  • Now you are ready to reassemble the phone
Aggiungi Commento
Linea Traguardo
Altre 6 persone hanno completato questa guida.
Chris
Membro da: 20/04/2011
227 Reputazione
1 Guida realizzata
Cal Poly, Team 15-13, Regan Spring 2011 Membro di Cal Poly, Team 15-13, Regan Spring 2011
CPSU-REGAN-S11S15G13
3 Membri
5 Guide realizzate
No need to full disassemble the phone. Just remove the back and the battery and unscrew the T5 screw, presto 20 minutes saved.
willdickerson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 15,035
