Introduzione
Use this guide to replace the keyboard cover of your BlackBerry Curve 8520.
Parti
Nessuna parte richiesta.
Insert a plastic opening tool into the small notch on the rear cover of the phone. Pry the rear cover up from the phone.
  • Insert a plastic opening tool into the small notch on the rear cover of the phone.
  • Pry the rear cover up from the phone.
Aggiungi Commento
Locate the slit between the top of the battery and the casing. Gently apply pressure on the top of the battery to trigger the spring release.
  • Locate the slit between the top of the battery and the casing.
  • Gently apply pressure on the top of the battery to trigger the spring release.
Aggiungi Commento
Remove the two Torx T6 screws to the left and right of the battery. Remove the two Torx T6 screws to the left and right of the battery.
  • Remove the two Torx T6 screws to the left and right of the battery.
Aggiungi Commento
Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath. Starting from one side, use a plastic opening tool to pry up the screen cover.
  • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
  • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
  • Once one side is loose, gently peel up the entire cover.
Aggiungi Commento
Insert the plastic opening tool in the seam along the side of the device. Slide the tool along the length of the seam, applying moderate force with the plastic opening tool. Carefully remove the faceplate.
  • Insert the plastic opening tool in the seam along the side of the device.
  • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
  • Carefully remove the faceplate.
Aggiungi Commento
Remove four T6 Torx screws from the front of the phone. Using tweezers, remove the keyboard buttons from the phone. Using tweezers, remove the keyboard buttons from the phone.
  • Remove four T6 Torx screws from the front of the phone.
  • Using tweezers, remove the keyboard buttons from the phone.
bb is nt a freely phone is a phone bcz of ringing some how it is nt
tankiso - Replica
Conclusione
Altre 27 persone hanno completato questa guida.
Matt
Membro da: 07/04/2011
1.708 Reputazione
5 Guide realizzate
Cal Poly, Team 9-62, Walters Spring 2011 Membro di Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 34,506
