Introduzione
This guide will show you how to replace the keyboard of your BlackBerry Curve 8310.
Press down on the battery release button and slide the back cover up with your thumb.
  • Press down on the battery release button and slide the back cover up with your thumb.
Aggiungi Commento
Pry from the top of the battery to pull it out.
  • Pry from the top of the battery to pull it out.
Aggiungi Commento
Slide the metal sim card cover to the unlock position.
  • Slide the metal sim card cover to the unlock position.
  • Remove the sim card.
  • The arrows on the sim card enclosure indicate the lock and unlock positions.
Aggiungi Commento
Remove the two T5 Torx screws circled at the top of the phone.
  • Remove the two T5 Torx screws circled at the top of the phone.
  • The T5 Torx screws may be covered by a white sticker.
Aggiungi Commento
Remove the red cover at the bottom of the phone.
  • Remove the red cover at the bottom of the phone.
  • You may have to work a spudger underneath to release the plastic clips.
Aggiungi Commento
Be careful not to damage the front cover's plastic clips while trying to separate it from the phone. Use a spudger to pry the front cover away from the side panels. Work the spudger around the entire phone until the front cover is free.
  • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
  • Use a spudger to pry the front cover away from the side panels.
  • Work the spudger around the entire phone until the front cover is free.
Aggiungi Commento
Remove the keyboard.
  • Remove the keyboard.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Mandy Chan
Membro da: 20/01/2012
88 Reputazione
2 Guide realizzate
Cal Poly, Team 10-32, Amido Winter 2012 Membro di Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,775
