Parti
Nessuna parte richiesta.
Remove the battery cover by applying pressure and sliding down to the silver square on the back of the phone.
  • Remove the battery cover by applying pressure and sliding down to the silver square on the back of the phone.
Aggiungi Commento
Remove the battery by prying under it with your finger or the plastic opening tool. Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  • Remove the battery by prying under it with your finger or the plastic opening tool.
  • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
Aggiungi Commento
Use a plastic opening tool (similar to the one shown) to carefully remove the two side bars of plastic. Use a plastic opening tool (similar to the one shown) to carefully remove the two side bars of plastic.
  • Use a plastic opening tool (similar to the one shown) to carefully remove the two side bars of plastic.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Use the plastic opening tool to carefully pry the back casing off.
  • Use the plastic opening tool to carefully pry the back casing off.
    • There are two small clamps on each edge that need to be unhooked before the casing will come off.
Aggiungi Commento
Pry off the front casing
  • Pry off the front casing
    • Be aware of sensors and other sensitive areas of the newly exposed electronics
Aggiungi Commento
After removing the front from the outer casing, the track ball will come off attached to the casing.
  • After removing the front from the outer casing, the track ball will come off attached to the casing.
Aggiungi Commento
Remove the track ball from the front case.
  • Remove the track ball from the front case.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
ryan
Membro da: 12/04/2013
41 Reputazione
5 Guide realizzate
Cal Poly, Team 13-64, Johann Spring 2013 Membro di Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 639
