Introduzione
This repair guide shows how to remove the battery on the BlackBerry 8703e.
Press the button with one hand while applying downward pressure with the other hand on the middle of the phone to slide the battery cover off. Remove the battery cover completely and set it aside.
  • Press the button with one hand while applying downward pressure with the other hand on the middle of the phone to slide the battery cover off.
  • Remove the battery cover completely and set it aside.
Aggiungi Commento
Locate the rectangular battery in the middle of the phone.
  • Locate the rectangular battery in the middle of the phone.
  • Locate the notch on the top right of the battery compartment.
  • Slide your fingernail in the notch, then lift upwards on the top of the battery to remove it from the phone.
  • Set the battery aside.
Aggiungi Commento
Conclusione
Cal Poly, Team 11-3, Forte Winter 2010 Membro di Cal Poly, Team 11-3, Forte Winter 2010
CPSU-FORTE-W10S11G3
5 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,174
