Introduzione
This is a guide on how to replace the logic board on your Blackberry 7510.
Parti
Nessuna parte richiesta.
Remove the battery cover and battery before continuing.
  • Remove the battery cover and battery before continuing.
  • Remove the six T6 Torx screws on the back of the phone.
  • Make sure to keep the screws somewhere that they will not get lost.
Aggiungi Commento
Using your finger nail or a spudger, carefully pry up the back cover.
  • Using your finger nail or a spudger, carefully pry up the back cover.
  • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
Aggiungi Commento
Lift off the back cover.
  • Lift off the back cover.
Aggiungi Commento
Remove the two T6 screws.
  • Remove the two T6 screws.
Aggiungi Commento
Remove the daughterboard. Remove the exposed vibration motor.
  • Remove the daughterboard.
  • Remove the exposed vibration motor.
Aggiungi Commento
Using the T6 Torx screwdriver,  remove the top screw.
  • Using the T6 Torx screwdriver, remove the top screw.
Aggiungi Commento
Using your spudger, carefully pry off back plate.
  • Using your spudger, carefully pry off back plate.
  • Use the same technique as with the plastic back cover. Circle around the back plate until all of it is pried up.
Aggiungi Commento
Remove the front cover and keypad.
  • Remove the front cover and keypad.
Aggiungi Commento
Remove one T6 Torx screw in the front bottom right of the board.
  • Remove one T6 Torx screw in the front bottom right of the board.
Aggiungi Commento
Carefully pry the screen from the board with your spudger. After prying it up, remove the screen from the board.
  • Carefully pry the screen from the board with your spudger.
  • After prying it up, remove the screen from the board.
Aggiungi Commento
Unscrew center T6 Torx screw in the center of the logic board. Remove the logic board from the phone.
  • Unscrew center T6 Torx screw in the center of the logic board.
  • Remove the logic board from the phone.
  • Replace with new logic board.
Aggiungi Commento
Conclusione
Neil Johnson
Membro da: 24/01/2010
12 Reputazione
6 Guide realizzate
Cal Poly, Team 14-44, Regan Winter 2010 Membro di Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,776
