Introduzione
This guide will show you step-by-step instructions on how to remove the SIM card from your RIM BlackBerry 7290.
Strumenti
Parti
Nessuna parte richiesta.
With your index finger, press down on the lock button to unlock the battery cover. Slide the battery cover down towards you to reveal the battery. Slide the battery cover down towards you to reveal the battery.
  • With your index finger, press down on the lock button to unlock the battery cover.
  • Slide the battery cover down towards you to reveal the battery.
Aggiungi Commento
Use your index finger to lift and remove the battery from the phone. Use your index finger to lift and remove the battery from the phone. Use your index finger to lift and remove the battery from the phone.
  • Use your index finger to lift and remove the battery from the phone.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Slide the SIM card holder to the left to unlock the SIM card.
  • Slide the SIM card holder to the left to unlock the SIM card.
Aggiungi Commento
Lift the SIM card holder up. Gently remove the SIM card from the SIM card holder.
  • Lift the SIM card holder up.
  • Gently remove the SIM card from the SIM card holder.
Aggiungi Commento
Conclusione
kmathew
Membro da: 17/10/2009
3 Reputazione
5 Guide realizzate
Cal Poly, Team 19-6, Maness Fall 2009 Membro di Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,859
