Salta al contenuto principale
BlackBerry 7290 LCD Replacement
Cosa ti serve
  1. BlackBerry 7290 LCD Replacement, Battery: passo 1, immagine 1 di 3 BlackBerry 7290 LCD Replacement, Battery: passo 1, immagine 2 di 3 BlackBerry 7290 LCD Replacement, Battery: passo 1, immagine 3 di 3
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. BlackBerry 7290 LCD Replacement: passo 2, immagine 1 di 3 BlackBerry 7290 LCD Replacement: passo 2, immagine 2 di 3 BlackBerry 7290 LCD Replacement: passo 2, immagine 3 di 3
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
  3. BlackBerry 7290 LCD Replacement, SIM Card: passo 3, immagine 1 di 1
    • Slide the SIM card holder to the left to unlock the SIM card.
  4. BlackBerry 7290 LCD Replacement: passo 4, immagine 1 di 2 BlackBerry 7290 LCD Replacement: passo 4, immagine 2 di 2
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
  5. BlackBerry 7290 LCD Replacement, Side Button: passo 5, immagine 1 di 1
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
  6. BlackBerry 7290 LCD Replacement: passo 6, immagine 1 di 2 BlackBerry 7290 LCD Replacement: passo 6, immagine 2 di 2
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
  7. BlackBerry 7290 LCD Replacement: passo 7, immagine 1 di 1
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  8. BlackBerry 7290 LCD Replacement: passo 8, immagine 1 di 3 BlackBerry 7290 LCD Replacement: passo 8, immagine 2 di 3 BlackBerry 7290 LCD Replacement: passo 8, immagine 3 di 3
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
  9. BlackBerry 7290 LCD Replacement: passo 9, immagine 1 di 2 BlackBerry 7290 LCD Replacement: passo 9, immagine 2 di 2
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
  10. BlackBerry 7290 LCD Replacement, Keypad: passo 10, immagine 1 di 1
    • To remove the phone's internals, start by loosening one side by pulling gently.
  11. BlackBerry 7290 LCD Replacement: passo 11, immagine 1 di 1
    • With one side loosened, simply lift the phone internals to separate from the front casing.
  12. BlackBerry 7290 LCD Replacement: passo 12, immagine 1 di 1
    • Turn the internals over to reveal the LCD display.
  13. BlackBerry 7290 LCD Replacement: passo 13, immagine 1 di 2 BlackBerry 7290 LCD Replacement: passo 13, immagine 2 di 2
    • Peel off the rubber keypad buttons from the face plate.
  14. BlackBerry 7290 LCD Replacement, LCD: passo 14, immagine 1 di 1
    • Locate a hook on the right side of the internals below the volume wheel.
    • Use a plastic opening tool to gently pry the hook, separating the LCD display from the logic board mounting plate.
  15. BlackBerry 7290 LCD Replacement: passo 15, immagine 1 di 2 BlackBerry 7290 LCD Replacement: passo 15, immagine 2 di 2
    • With the clip unhooked, gently separate the display from the phone internals by pulling.
Conclusione
kmathew
Membro da: 10/17/09
3 Reputazione
5 Guide realizzate
Cal Poly, Team 19-6, Maness Fall 2009 Membro di Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 5,938
