Introduzione
The outer shell of the BlackBerry 7280 contains two parts, the back case and the front case. This guide demonstrates how to remove the front case by unscrewing the supporting bracket and then prying the front case away.
Parti
Nessuna parte richiesta.
With your thumb press down on the locking- button on the back of the BlackBerry 7280. Slide the battery cover off the device. Slide the battery cover off the device.
  • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
  • Slide the battery cover off the device.
Aggiungi Commento
Remove the lithium-ion battery from the back of the device using your index finger. Remove the lithium-ion battery from the back of the device using your index finger.
  • Remove the lithium-ion battery from the back of the device using your index finger.
Aggiungi Commento
Hold the device with both hands. Lift the SIM card holder using your thumb and index finger. Remove the SIM card from the device.
  • Hold the device with both hands.
  • Lift the SIM card holder using your thumb and index finger.
  • Remove the SIM card from the device.
Aggiungi Commento
Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside. The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
  • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
Aggiungi Commento
Use the plastic opening tool to pry the back case away from the front case. Use the plastic opening tool to pry the back case away from the front case.
  • Use the plastic opening tool to pry the back case away from the front case.
Aggiungi Commento
Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket.  Set aside the screw and the bracket. Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket.  Set aside the screw and the bracket.
  • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
Aggiungi Commento
Remove the front plastic case from the metal bracket. Remove the front plastic case from the metal bracket.
  • Remove the front plastic case from the metal bracket.
Aggiungi Commento
Conclusione
Andrew Catlin
Membro da: 11/03/2013
16 Reputazione
3 Guide realizzate
Clemson, Team 12-2, Benson Spring 2013 Membro di Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 160
