Introduzione
The guide will show you how to remove and install the BlackBerry's keypad.
Turn over your BalckBerry 7100g so that the back cover is facing up.
  • Turn over your BalckBerry 7100g so that the back cover is facing up.
  • Locate the battery cover release button near the bottom of the back panel.
Aggiungi Commento
Push down on the release button with one thumb. Slide the battery cover off with the other thumb. Slide the battery cover off with the other thumb.
  • Push down on the release button with one thumb.
  • Slide the battery cover off with the other thumb.
Aggiungi Commento
Remove the battery from the battery housing by flipping up the top of the battery.
  • Remove the battery from the battery housing by flipping up the top of the battery.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Locate the silver strip near the top of your BlackBerry. Use a plastic opening tool to pry off the edge of the silver lining. Slide the tool along the length of the silver strip to completely remove it.
  • Locate the silver strip near the top of your BlackBerry.
  • Use a plastic opening tool to pry off the edge of the silver lining.
  • Slide the tool along the length of the silver strip to completely remove it.
Aggiungi Commento
Do not lose the screws. They are quite small and can easily be misplaced. Locate and unscrew the four (4) screws using a T6 screwdriver.
  • Do not lose the screws. They are quite small and can easily be misplaced.
  • Locate and unscrew the four (4) screws using a T6 screwdriver.
Aggiungi Commento
The keypad cover may fall out of the housing when prying the housing apart. Tightly pinch the top of the front and back halves of the housing. Carefully pry the two halves of the housing apart.
  • The keypad cover may fall out of the housing when prying the housing apart.
  • Tightly pinch the top of the front and back halves of the housing.
  • Carefully pry the two halves of the housing apart.
Aggiungi Commento
You can now easily remove the "guts" of the phone from the housing.
  • You can now easily remove the "guts" of the phone from the housing.
Aggiungi Commento
Turn the "guts" over so the speaker is facing up. Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver. Separate the battery housing from the motherboard.
  • Turn the "guts" over so the speaker is facing up.
  • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
  • Separate the battery housing from the motherboard.
Aggiungi Commento
Pull the keypad off of the motherboard.
  • Pull the keypad off of the motherboard.
    • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
Aggiungi Commento
Conclusione
Mai Chao Her
Membro da: 11/04/2010
16 Reputazione
1 Guida realizzata
Cal Poly, Team 25-87, Amido Spring 2010 Membro di Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,348
