Salta al contenuto principale
Black and Decker Toast R Oven Knobs Replacement
Cosa ti serve
  1. Black and Decker Toast R Oven Knobs Replacement, Knobs: passo 1, immagine 1 di 1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster upside down and remove the two Phillips #4 1 cm screws attached to the side panels.
  2. Black and Decker Toast R Oven Knobs Replacement: passo 2, immagine 1 di 2 Black and Decker Toast R Oven Knobs Replacement: passo 2, immagine 2 di 2
    • Pull down and out to remove side panels from the unit
    • Repeat for the other side.
  3. Black and Decker Toast R Oven Knobs Replacement: passo 3, immagine 1 di 1
    • Remove the bottom vent.
    • This should come off fairly easy.
  4. Black and Decker Toast R Oven Knobs Replacement: passo 4, immagine 1 di 1
    • Remove the two Phillips #4 1 cm screws that connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Knobs Replacement: passo 5, immagine 1 di 1
    • Remove the crumb tray (bottom metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Knobs Replacement: passo 6, immagine 1 di 1
    • Remove the aluminum strip on the bottom of the unit.
  7. Black and Decker Toast R Oven Knobs Replacement: passo 7, immagine 1 di 1
    • Remove knobs by pulling up on them.
  8. Black and Decker Toast R Oven Knobs Replacement: passo 8, immagine 1 di 1
    • Unhook the bottom of the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful.
  9. Black and Decker Toast R Oven Knobs Replacement: passo 9, immagine 1 di 1
    • Begin to detach the back panel from the toaster unit and unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
Conclusione
To reassemble your toaster, follow these directions in reverse.
Jonathan
Membro da: 09/18/12
281 Reputazione
5 Guide realizzate
Cal Poly, Team 2-10, Propen Fall 2012 Membro di Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 Membri
5 Guide realizzate
Un commento
very interesting post
James Evans - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 36
Tutti i Tempi: 4,836
